Sep 29, 2016
The Bluetooth standard’s maximum data rate is, at best, 3 Mbps or about 2.1 after protocol overheads take their cut.
Wi-Fi on the other hand, maxes out anywhere from 54 to 1300+ Mbps depending on whether you have “g”, “n”, or “ac” Wi-Fi plus any enhancements in the adaptors and router support.
So no, Bluetooth is not faster than Wi-Fi. Not even vaguely close.
Bluetooth version 3 and version 4 have higher data rates, but the actual data transfer in those implementations happens over Wi-Fi; Bluetooth is only used to set up and negotiate the connection.
