Home > Think Tank > What is the difference between 32-bit and 64-bit versions of Windows?
Aug 1, 2016
1. What is the difference between 32-bit and 64-bit versions of Windows?
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information. The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system.
2. How can I tell if my computer is running a 32-bit or a 64-bit version of Windows?
To find out if your computer is running a 32-bit or 64-bit version of Windows in Windows 7 or Windows Vista, do the following:
① Open System by clicking the Start button, right-clicking Computer, and then clicking Properties.
② Under System, you can view the system type.
3. Which version of Windows should I install: the 32-bit version or the 64-bit version?
To install a 64-bit version of Windows, you need a CPU that's capable of running a 64-bit version of Windows. The benefits of using a 64-bit operating system are most apparent when you have a large amount of random access memory (RAM) installed on your computer, typically 4 GB of RAM or more. In such cases, because a 64-bit operating system can handle large amounts of memory more efficiently than a 32-bit operating system, a 64-bit system can be more responsive when running several programs at the same time and switching between them frequently.
How to Enable or Disable Snap Assist in Windows 11How to Shut Down Your PC Without Waiting for an UpdateHow to Upgrade to Windows 11 26H2 Using a Single Command
