Home > Think Tank > How to Run Memory Diagnostic Tool to Fix Memory Problems?
Jul 17, 2014
Like any other computer component, RAM needs to be in tip-top state to operate effectively and efficiently. This would mean correcting all invalid memory bits, and storing data in a perfect way.
To corroborate the health of RAM, Windows comes with an in-built memory diagnostic tool that can be accessed from Control Panel, shown below:
Step1. Type “control panel” in the Start Screen (Windows key)
Step2. Click Control Panel icon from the search results
Step3. Click System and Security Scroll down to choose Administrative Tools Locate and double click Windows Memory Diagnostic
Step4. Follow onscreen instructions: you can choose to restart right and check for problems or check for problems the next time I start my computer according to your need.
90
